1997 Toyota Avalon White Smoke
AVALON123
1997 Toyota Avalon 73, 560 miles.
My gaskets were fixed but I still smell a burning smell when I drive the car. Mechanic at Toyota said it was could either be a valve job or gasket. I tried the gasket fix but car is still smelling like burning oil. Sometimes after traveing on the freeway at 75 to 80 mph ,there is smoke coming out of the tailpipe. The smoke is white. This is driving me crazy, car is otherwise in good shape.
Thanks for any help, advice anybody can offer. Also, service technician said the valve job would cost around 1,100.00 to repair, does that sound right?
Dec 13, 2006 at 12:53 AM
2CARPRO JACK
  • 11,533 POSTS
That sounds a little premature for a toyota to be having that kind of problem,but not totally unheard of.Always remember the dealer prices are higher than an independant repair shop.The good part is that you get factory Toyota parts
Dec 13, 2006 at 2:24 AM
MMPRINCE4000
  • 8,548 POSTS
White smoke would indicate coolant, which indicates a head gasket or intake gasket.
Overheating is usual cause.
I would get another opinion from another Toyota dealer.
If head gaskets have been changed, then possible head is cracked.
If so, you would better off replacing engine with used one.
And as Jack said, VERY unusual with a Toyota.
Nov 13, 2010 at 10:35 AM
Suggested Repair
White smoke points to coolant entering the combustion chamber, commonly from a head gasket or intake gasket, or a cracked head if the gaskets were already replaced. Get a second opinion from another Toyota dealer or independent shop before paying for a valve job, and consider a used engine if the head is cracked.
Conversation Summary
The owner of a 1997 Toyota Avalon with about 73,560 miles still smells burning oil after a gasket repair and sees white tailpipe smoke after freeway driving. A dealer suggested a valve job or gasket work and quoted about $1,100 for the valve job. Experts said white smoke usually indicates coolant from a head or intake gasket, often after overheating, and that a cracked head is possible if the gaskets were already replaced. They recommended another opinion and noted a used engine may be more practical if the head is cracked; dealer prices are typically higher than independent shops.
