2000 Toyota Avalon Extreme Tire Wear
DANL06
@69,000 Replaced Original Tires, @100,000 Replaced next set of Tires no appearant Alignment Problems. @146,000 Tires need to be replaced again. Alignment in spec. Tire pressure down 4 psi at inspection. Tires worn down accross tread a bit more to the outside of all 4 tires. These Tires are getting less than 1/2 expected milage??
Apr 27, 2006 at 2:40 PM
LOSONE
  • 1,616 POSTS
There are four reasons for that kind of wear.
1. Poor quality tires.
2. Improper tire pressure
3. Improper 4 wheel alignment
4. Poor driving habits.
May 1, 2006 at 4:13 AM
Suggested Repair
Check tire quality, keep pressures at spec, verify a full four-wheel alignment, and review driving habits that cause outside-edge wear.
Conversation Summary
The owner of a 2000 Toyota Avalon reports tires lasting less than half the expected mileage, with slightly more wear toward the outside of all four tires. Alignment was in spec and pressure was only about 4 psi low. The expert lists four possible causes: poor-quality tires, improper pressure, improper four-wheel alignment, and poor driving habits.
