2000 Toyota Avalon AC Drain Blocked
ANNEET
Hi, Thanks to your site I have determined the ac drainage is most likely the reason I am getting interior flooding . Could you estimate a cost associated with this repair. I have seen tips to unblock drain hose but dont feel comfortable trying this myself. thanks for your help
May 26, 2006 at 4:24 AM
LOSONE
  • 1,616 POSTS
Start with the outside drain hose. Make sure it is connected to the A/C plenum. It is easy to clean just be carefull you don't blow high pressure air as it could cause other damage. There is a good chance you have a cracked hose.
It is a tough head angle but after you remove the hose and use a pipe cleaner, poke it inside the case hole and make sure it is clean.
May 26, 2006 at 10:41 AM
Suggested Repair
Confirm the outside A/C drain hose is connected to the plenum. Remove the hose, clean it and the case opening with a pipe cleaner, and avoid high-pressure air. Also check for a cracked hose.
Conversation Summary
The owner of a 2000 Toyota Avalon has interior flooding and believes the A/C drain is blocked, asking about repair cost rather than clearing it themselves. The expert advises checking that the outside drain hose is connected to the A/C plenum, cleaning it carefully without high-pressure air, and using a pipe cleaner in the case opening after removing the hose. A cracked hose is also possible.
