2000 Toyota Avalon A/C Musty Odor
DLANGHAMMER
2000 Avalon, V6, 55,000 mil
When I turn on the A/C, the air coming out stinks like a mildew order. It lasts long enough to get in my clothes, etc.
I bought and used per the directions some A/C bacteria eliminator. But, its back.
I think it might be the drain plug that has the mildew, but I don't know where the drain plug is or how to properly clean it out.
Any help is appreciated. I
Oct 29, 2007 at 11:22 AM
BLACKOP555
  • 10,386 POSTS
ok first are you getting low on coolant every few weeks or month of driving? also is there ever fog on your window that is kind of oily or water leaking in car then you may have a bad heater core.
Oct 29, 2007 at 12:15 PM
DLANGHAMMER
I have not replaced any coolent. I have no water leaks in the car. And, I have no fog on the front or back windows.
Any other suggestions?
P.S. I bought the car new in 2000 and I am the only driver. Thanks.
Debbie
Oct 29, 2007 at 1:52 PM
BLACKOP555
  • 10,386 POSTS
take out the blower motor in the engine compartment and spray in there ith bleech water and let it circulator thruough the ducts that should elmimate it if not then id have the heater core checked.
Oct 29, 2007 at 1:55 PM
Suggested Repair
Remove the blower motor and spray a bleach-and-water solution through the ducts so it circulates and kills mildew. If the odor returns, have the heater core checked.
Conversation Summary
A 2000 Toyota Avalon owner reported a recurring musty mildew smell from the A/C that soaked into clothing. An A/C bacteria eliminator only helped temporarily, and the owner suspected the drain. The expert asked about coolant loss, oily window fog, or interior water leaks as signs of a bad heater core. The owner reported none of those issues. The expert then advised removing the blower motor and circulating bleach water through the ducts, and checking the heater core if the odor remains.
