Engine shut off while driving and will not start
CARKID1969
No there is no check engine light on, a mechanic told me that it could be my pcv, egr, valves or even my throttle body is clogged. Let me know what I should check first and what is the least expensive way to go.
Saturday, October 10th, 2020 AT 11:16 AM (Merged)
RHALL77
  • 3,361 POSTS
Check your plug wires and egr first. Also look for a vacuum leak
LINDAARMSTRONG
  • 1999 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • 4WD
  • 160,000 MILES
Replaced fuel pump now car will crank but will not stay running.
Saturday, October 10th, 2020 AT 11:17 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I would suggest to retest the fuel pressure.It's possible you may have bought a defective fuel pump.If you don't have access to a fuel pressure tester your local auto parts store have a tool loaner program and can rent you one.Here is a tutorial showing how to test:
Your car specification shows the pressure to be 41-47 p.s.i. Hope this helps and thanks for using 2CarPros.
Danny-
GLORIA SHUMPIS
  • 4 CYL
  • FWD
  • 103,000 MILES
Today while driving my car stalled and I rolled to the side of the road. When I tried to start it, I had no lights now power what so ever. It would not turn over it was just dead. I wait a few minutes tried again. Nothing. I wait longer and tried to start it, the lights came on and it start. What could be the problem.
MMPRINCE4000
  • 8,548 POSTS
Take it to any autoparts store and have the charging system tsted for free, this includes battery, alt, alt. Ripple, alt. Amp output and starter draw.
Check all battery connections and make sure they are clean and tight.
Other possibilities are ign. Switch.
GATITAFINA
  • 4 CYL
  • 90,000 MILES
I have a 1999 chevy cavalier and it shorts out and shuts off when I pull out of my driveway in reverse. Also all dash lights come on abs, check engine seatbelt etc
GMTECH
  • 537 POSTS
Does it short out or just shut off? All the lights will come on if the engine shuts off. Perhaps the vehicle is not running very well and the rpm is too low when you put it in reverse. Have it checked out at shop to see.
99CAVALIERGIRL
  • 141,000 MILES
I have a 99 chevy cavalier and it turns over and runs just fine for the most part, but sometimes it dies randomly. Its weird because to turn it on all I have to do is connect jumper cables to the battery terminas. I dont need another car to get it to start, as if there were a short or something. It dies sometimes when I turn it off. Today for the very first time it died while driving which was crazy. When it dies it makes like a tick tick tick noise.
Saturday, October 10th, 2020 AT 11:19 AM (Merged)
CARADIODOC
  • 33,922 POSTS
Sounds like you need to clean and tighten the battery cables. GM's side post design is not very friendly or easy to get high current through so they have to be maintained. Also, due to the generator design, they develop huge voltage spikes that can destroy its internal diodes and voltage regulator and they can interfere with computer sensor signals. The battery is the key component in dampening and absorbing those spikes. With a poor connection, those voltage spikes could be confusing the Engine Computer.
It is common to go through four to six replacement generators in the life of the car. If it fails, to reduce the number of repeat failures, replace the battery at the same time unless it is less than about two years old.
99CAVALIERGIRL
Hi and thank you for replying, okay so your saying to disconnect and clean the terminals and battery itself right? And if the problem persist to try a new battery?
CARADIODOC
  • 33,922 POSTS
My comment about replacing the battery is something I include for future reference for all GM car owners for '87 and newer models. The generators are a real common problem and the aged battery is the solution to repeat generator failures. As the batteries age, they lose their ability to dampen and absorb those harmful voltage spikes.
In your case the jumper cables were the clue. They will put tension on the connections by their very nature of being a stiff wire. With the better connection, that's why the engine will crank. Start by taking the cables off, (remove the negative one first because if the wrench hits the metal of the car, nothing will happen. If you take the positive off first or put it on last, and the wrench hits the car, you'll have a serious spark issue. Sparks can lead to a battery explosion from the hydrogen gas they give off). Scrub the cable ends and battery terminals with a wire brush to shine them up. If you see excessive white corrosion that looks like cauliflower, that is a sign the battery is about to fail within the next six months to a year, so you can be justified in replacing it. There are a lot of chemicals and coatings for that corrosion but none can address the underlying cause of the imminent battery failure.
99CAVALIERGIRL
I cleaned the terminal there a definate improvement in the battery charge I had autozone check. Thank you very much well see if that fixed the problem ill keep you posted. I really appreciate your great advice.
THEODORELAME
  • 17,000 MILES
Stalling about four months ago I had my chevy in the garage and the mapp sencor was changed and it ran good, now it is doing the same thing again, it starts up and stalls out. It will run when it heats up but then it's like it is not getting any gas
  • 109,896 POSTS
If the check engine light is on, have the computer scanned to identify if the map is bad again. If there is no light, check for vacuum leaks and check the idle air control valve for function. Either of these items could cause it to stall at idle.
THEODORELAME
Some times the engine light is on and then it goes off, sometimes when the light is on it will idle pretty good and then the fan turns, after they changed the mapp senser it was running good but after that it was heating up alot and I did not think any thing of this can heating burn out the mapp senser?
  • 109,896 POSTS
The map didn't cause the overheating. It sounds like a bad sensor at some point. You need to have the computer scanned to identify which one is the problem.
