After replacing the alternator, the engine turns over slowly and backfires and will not fire?
181,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
TRAVON SPEED
Got into my car this afternoon and started my car only to find an error message stating that there is a problem with my charging system. So, I drove to Orielly auto and shut the car off and asked if they could test my alternator and they did. It was bad, so I shut the car off and got the price only when I came out of the store my car gave me a click and would not even try to start. So, I bought an alternator and while I was putting it in, I had jumper cables from my friend's car hooked to my battery and when I was done the car turns over slowly and backfires and will not necessarily fire. I'm not sure what's going on with it. I know it should be getting fuel because I hooked up the fuel pump to direct power so I know that can't be my issue and I'm very lost now and out of ideas. Can anyone please help me?
Nov 22, 2022 at 12:46 PM
  • 110,246 POSTS
This sounds like a voltage issue. Nothing would have changed to cause a backfire by replacing the alternator. Take a look through this link:
https://www.2carpros.com/articles/engine-backfires-while-running
There is a chance if your battery is low enough, jump-starting won't work. What is the voltage at your battery when not connected to jumpers? If you have a helper turn the key to the start position, what does the voltage drop to?
Nov 24, 2022 at 11:32 AM
