2005 Cadillac STS 2005 Cadillac STS Help Will Not Start
MEASTMAN76
  • 2005 CADILLAC STS
  • 6 CYL
  • 68,000 MILES
My Cadillac STS will not recognize that the car is in park. While it is in park, the message says to put the car in park. When we put it in park or neutral, and hit start, the whole dash goes black. The battery has been tested and it is okay. Please help! Thanks, Melissa
Monday, November 8th, 2010 AT 11:59 AM
FACTORYJACK
  • 4,159 POSTS
Does it start? If the dash blanks that indicates low voltage, does the starter click? If the battery tests good, it was tested improperly, has an internal short(battery), or a poor connection.
Tuesday, November 9th, 2010 AT 11:13 PM
MEASTMAN76
The car is not starting. It will not even turn over. As soon as the engine start button is pushed, everything goes black. We tried to start it with jumper cables from another vehicle and the same problem occured. Could it be a computer issue?
Wednesday, November 10th, 2010 AT 7:34 AM
FACTORYJACK
  • 4,159 POSTS
I would not suspect a computer issue, at this point. How does it react after it goes blank? Is there some clicking under the hood, when it is triied. I still suspect a source voltage or connection problem.
Wednesday, November 10th, 2010 AT 10:48 PM
MEASTMAN76
No clicking or sounds. It goes completely dead and everything goes black. We hooked up another battery and it still did the same thing. The voltage on the battery is good.
Sunday, November 14th, 2010 AT 7:40 PM
CASSANDRA ROSE
Did you ever figure out the problem? I'm having similar issues.
Monday, February 28th, 2022 AT 11:54 AM
  • 52,797 POSTS
If the ECM does not see the park, it will not start. There is a position sensor that sends that signal.
https://www.2carpros.com/articles/car-not-running-advanced
What is your car information?
Wednesday, March 2nd, 2022 AT 1:30 PM
