1996 Cadillac STS cranks but wont start
TL1969
  • 1996 CADILLAC STS
1996 Cadillac STS 6 cyl Automatic
96 cadillac cranck but wont start drove the car to work put in park it cut off on its on changed the fuel pump started up no problem a month later same problem changed the fuel pump again and the fuel filter started up no problem a few days later same problem if I let the car sit for a day or so it will start up no problem but I cant figure out what is stopping it from getting fuel to start its like something is clogged up the service emission light came on a bout a month ago would that have any thing to do with it not getting fuel or are there other fuel filters that may need to be changed in the fuel line and does the catalytic converter have anything to do with it not starting if its clogged plz help I haze small kids and this is my only car thanks
Tuesday, August 4th, 2009 AT 8:46 AM
IMPALASS
  • 3,112 POSTS
Hello -
Okay, so we are on the same page. You have a 1996 Cadillac Seville STS... What is the engine size in liter?
Are you saying when you first start it in the morning it starts fine but after it is driven it will not start?
You have changed the fuel pump and filter twice... Yes?
How many miles are on the vehicle
Please go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Tuesday, August 4th, 2009 AT 11:11 PM
