Listen under the hood at key up, for a relay that clicks when the key is turned on, and again after a couple seconds. The best bet is to check for power and ground at the fuel pump connector. If you have power and ground for two seconds at key up, or power and ground all the time when cranking, replace the pump and filter.
SPONSORED LINKS
Wednesday, May 19th, 2010 AT 11:32 PM
