Security lights on and will not start?
247,838 MILES
IMPALA01NOSTART?
I have put a new switch in. I left the car on overnight. I've done all the resistors, 10 minutes, 30 minutes. Resets and I'm still not starting. Dealer say the car is too old for them.... Had a buddy of mine work on the car for 2 months.... Still locked ... please help me...!
Aug 26, 2024 at 6:07 PM
  • 55,694 POSTS
Is the security light flashing? If so you are correct the security system is enabled. Here is information telling you the key does not need to be coded.
The ignition lock cylinder and keys do not contain any coded electronic components. The lock cylinder housing contains the coded electronic components. Changing an ignition lock cylinder or adding a key is a purely mechanical process which does not affect the vehicle theft deterrent system. To add a key, simply cut a new key to match the existing one. To change the lock cylinder, simply replace the existing lock cylinder with one of the same type.
If you replace any of these parts the vehicle may not start for 10 minutes. This is the long tamper mode. If this occurs, the system must go through a long tamper mode cycle. During this time the SECURITY indicator will be flashing for the full 10 minutes and DTC B3031 will be set. The BCM and the PCM require the full 10 minutes in order to complete a learn cycle. The ignition switch must remain in the ON position until the SECURITY indicator stops flashing. You will need to repeat the cycle if the ignition switch does not remain in the ON position. When replacing any of the above parts, perform the Programming Theft Deterrent System Components procedure.
You might want to try a hard system reboot, please go over this guide to help:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Aug 27, 2024 at 3:21 AM
