Relay problem (not firing)
268,122 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DAWNNETTE
I recently (four months ago) rebuilt transmission, then a week later had to put a new fuel pump, then a fuel pressure regulator. It ran fine (minus a little power) for seven hundred and fifty miles.
Now my ignition relay has gone out, or so I thought. I put a new relay, and it is still not firing. And now my battery went dead when it should not have. When I turn the key on, without trying to start it, I keep hearing a spark from around the alternator, and then the battery stopped working.
When it broke down two days ago. My nephew pulled the relay and turned it and put it back in and it started. I do not understand, because I put a new ignition relay and it still does not start.
Please help
Jan 11, 2017 at 1:44 AM
HMAC300
  • 48,601 POSTS
check to make sure the relay I sin right then try another key it may be that. Not a new key because it will need programming to your truck then check all fuses in under hood fuse box.
Jan 11, 2017 at 4:19 AM
