1999 Chevy Silverado will not start
BIGRDVL
  • 1999 CHEVROLET SILVERADO
  • 6 CYL
  • 4WD
  • MANUAL
  • 149,000 MILES
3 days ago, started up ran rough for 2 miles then ok. Low on gas, 2 days ago started up, let warm up 5 min, ran rough for 1 mile then ok. Filled up with gas, 1 day ago very hard to start. Would turn over ok no fire or gas? Finally started, let warm, ran rough for 1 mile. Changed oil, checked air filter, greased, changed in line fuel filter. Ran ok, this am would not start. Any suggestions would be greatly appreciated, Tks, Randy
Wednesday, June 4th, 2008 AT 6:34 AM
RHALL77
  • 3,361 POSTS
Does it try to start. Check your fuel pressure regulator and see if it is leaking. Also check and see if you are getting fuel pressure, you fuel pump might be getting worn out
Wednesday, September 2nd, 2020 AT 2:45 PM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
