updated 3-6-09
It's a 5.3 liter vortec with the fuel rail and regulator on the exterior.
THE INJECTOR PULSE IS QUITING AFTER START UP. WHAT WOULD CAUSE THIS? THERE ARE NO CODES COMING UP, NO SECURITY LIGHT EXCEPT WHEN THE DOOR IS OPEN. THE BATTERY LIGHT IS ON EVEN AFTER THE BRIEF START BUT THE VOLTS GUAGE READS 13+. THE FUEL PRESSURE IS 57 PSI AND DROPS TO 49, AFTER SHUT OFF IT JUMPS BACK UP TO 57. THE PASSLOCK VOLTAGE WIRES READ 10 VOLTS ON THE POS, 0 ON THE NEG AND 5.4 ON THE YELLOW. WITH IGNITION ON THE YELLOW READS 5.7 VOLTS. IS THAT THE PROBLEM?
Monday, March 2nd, 2009 AT 12:22 PM
