Now it will turn over but will not run?
TIMBOCHEVY1500
  • 1999 CHEVROLET SILVERADO
Hi I have a 1999 chevy silverado 1500 2 wheel drive 4.8 litre v8 and the starter went out on it about 2 months ago and just got around to replacing it today. Now it will turn over but will not run I checked the fuel filter and it was fine also the spark plugs, and if it was getting fuel. At first it wouldnt sputter or anything but after I took the fuel filter off and replaced it it started to sputter and spat a little bit but then would just die on me and I have no idea what it is can anyone give me some ideas please I need truck just finally found a job and need to be able to get to it lol
Sunday, October 3rd, 2010 AT 9:32 PM
Clearly the starter would not affect the starting of the vehicle outside of just spinning the engine. So, if the engine is turning then the starter is operating properly.
At this point we need to run through these couple of guides to find out why the engine is not starting.
https://youtu.be/dCjmRL3p4Cs
Here is a guide on how to check the fuel pressure as this is what it sounds like to me the issue is:
I suspect you have a fuel pump that has failed so I would suggest we start with this and then see what the pressure is. Please let us know what questions you have.
Thanks
Saturday, September 25th, 2021 AT 7:41 PM
Related Engine Not Running Content
How to fix an engine that wont start
VIDEO
