Power window issue?
BW74
  • 46 POSTS
I actually found a guide on eBay but before I put it in the roller was in really bad shape on the regulator, so I put a new one of them in and now even before putting the window channel and guide back in it only rolls up three quarters of the way and stops. Almost like the roller is binding but it slides back and forth on the track just fine.
Tuesday, June 27th, 2023 AT 6:16 PM
  • 109,858 POSTS
When you are raising the window, does it appear to go up straight? It could be binding in the tracks.
Tuesday, June 27th, 2023 AT 7:20 PM
BW74
  • 46 POSTS
This is with holding the window straight in the door channel itself without the other track even in.
Wednesday, June 28th, 2023 AT 6:05 AM
  • 109,858 POSTS
When you are pressing the window up button and it stops partially up, does the motor just stop or does it continue to work but not move the glass?
Wednesday, June 28th, 2023 AT 8:54 PM
BW74
  • 46 POSTS
It sounds like it just slows down to nothing. If you manipulate the window and keep hitting the button it eventually goes up. Without the window and the regulator moves up and down fine. Only started to get stuck after I put the new regulator wheel on.
Thursday, June 29th, 2023 AT 5:59 AM
  • 109,858 POSTS
It sounds like that is where the problem is. When you installed it, did everything go together easily? Did you lubricate all the moving parts?
Thursday, June 29th, 2023 AT 9:57 PM
