Thank you for the donation.
The problem should be at the starter.
Check if the cable terminal connector and solenoid wires are properly seated and not touching each other. If both are ok, the problem is caused by the terminal which has turned from its original position and when this happens, the solenoid is now shorted direclty to power source and when the battery is connected, it would work the starter.
SPONSORED LINKS
helpful?Yes
Thursday, December 31st, 2020 AT 10:32 AM
(Merged)
