Poor acceleration
PATRICIA SUTTON
  • 14 POSTS
I have not been able to delete the code. Tried again today too.
If the AC is unrelated to the code, I do think it needs servicing though. My vehicle squealed when it first started up with the fan on. Turn the fan off, the squeal went away.
Monday, August 12th, 2019 AT 5:40 PM
  • 109,872 POSTS
Either the squeal is from a loose belt or the compressor is going bad an has too much of a drag.
Monday, August 12th, 2019 AT 6:27 PM
PATRICIA SUTTON
  • 14 POSTS
What is that solution? To both that is. Or either.
And thank for all your help! It really is appreciated!
Monday, August 12th, 2019 AT 7:21 PM
  • 109,872 POSTS
Have you checked to make sure the belt is tight? If it seems loose, then suspect the belt tensioner. If it is tight, then suspect the compressor may be starting to seize.
Tuesday, August 13th, 2019 AT 10:13 PM
