CEL(check engine light) with loss of power light on
MIKEHICKS1
  • 2002 SATURN VUE
  • 2.2L
  • 4 CYL
  • FWD
  • 109,000 MILES
Just purchased and of course light goes on. Had code read and it appears to be a voltage differences from point A to point B. I assume that is pedal to throttle body. The car runs no different then before the lights lit up. There does not appear to be a clear reason known as a lot of people appear to have similar problems. How do I remedy this without tossing money down a shaft?
Thursday, November 10th, 2016 AT 3:05 PM
SATURNTECH9
  • 30,869 POSTS
Let's start with what are the exact code numbers not code descriptions? That would be a letter followed by a four digit number? I really need those that is the first thing I would do if I was there.
Friday, November 11th, 2016 AT 6:43 AM
SATURNTECH9
  • 30,869 POSTS
Some of those vues had water leak in and corrode wire terminals and set throttle pedal codes.
Friday, November 11th, 2016 AT 6:45 AM
