The car does not start
JDL
  • 16,098 POSTS
Welcome to the forum, engine cranking, do you have spark at the plugs? Are there any trouble codes? Use a gage and check fuel pressure.
Thursday, January 9th, 2020 AT 12:34 PM (Merged)
Its looks similar to this in the starter motor-
MJF025
Yep. Thats what it was. Thanks.
LILJAY74
  • 1994 PONTIAC TRANS AM
  • 98,000 MILES
My car will not start it turns over and cranks It will run for a minute but then it cuts back off. It has been sitting for about a year changed fuel filiter starter, and ignition but I don't know what to do at this point. Do you what the problem could be. I am stuck and not sure what to do at this point.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuelpressure first. Should be 41-47 psi cross a&b on aldl below lh dash by steering column count light flashes in series of 3 if it's 12 that is normal for key on and reading light.
2CP-ARCHIVES
  • 4,540 POSTS
  • 144,000 MILES
I replaced a new fuel pump and filter and also a fuel relay charged my battery full and it sill wont start. It turns but doesnt start.? What could it be?
HMAC300
  • 48,601 POSTS
Scan for codes, and check fuel pressure first. Check to see if you are getting spark. If you think it is a fuel issue, use a gauge and check fuel pressure. If it cranks good but won't start, have a helper crank it, while you visually check for spark at the spark plugs.
DRACOGI123
  • 1993 PONTIAC TRANS AM
  • V8
  • 60,100 MILES
I have a 1993 Trans Am, after I installed headers I noticed that the car started running ruff and hesitated when I accelerated. Need help please, what should I do. Thank you so much in advance.
DOCFIXIT
  • 18,828 POSTS
Where O2 sensors installed?
DRACOGI123
Good question, I'm not sure unfortunately I did not install the headers so I'm not sure where the 02 Sensors were installed. I have uploaded some pics for better view.
Thanks you so much....
https://www.2carpros.com/forum/automotive_pictures/426147_Left_Side_Header_2.jpg
https://www.2carpros.com/forum/automotive_pictures/426147_Right_Side_Header_1.jpg
DOCFIXIT
  • 18,828 POSTS
Going to need to jack up and see if O2 is installed.
Also check for codes find ALDL under dash next to column.
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_224.jpg
jumper from term A to B key on engine light will flash. so flash, flash pause flash is 21. post codes
