gas tank
PONTIAC SUNBIRD
RANDY SUTTON
how do you drain the gas tank on a 1990 sunbird?
Jun 5, 2006 at 7:18 AM
SYNCRAIT
  • 235 POSTS
the best way to drain any tank is to syphon it all out, you can buy one at the store pretty cheap, or if you like gas you can just take a hose and suck the end till gas comes out then drop the end in your hand so it is lower than the bottom of the gas tank and it will drain into your pail/whatever
Jun 5, 2006 at 7:40 AM
