Thanks
1993 Pontiac Sunbird Stuck in Park
Thanks
Try spraying some penetrating oil like WD-40 down there and let it soak. I have found lots on gunk in a stuck release cable before.
Suggested Repair
Inspect the brake-shift interlock (shift release) that unlocks the shifter when the brake pedal is pressed. Because the shifter binds only in Park and moves freely through the other gears, a binding shift cable is less likely.
Conversation Summary
The owner of a 1993 Pontiac Sunbird with an automatic transmission reported that the shifter is very difficult to move out of Park but shifts freely through the other gears, and asked whether a cable was the cause and how to fix it. An expert advised that the problem is more consistent with the shift-release mechanism, which unlocks the shifter when the brake is pressed, than with a shift cable, which would typically bind in more than one gear. Another participant suggested checking the release cable and spraying penetrating oil to loosen accumulated gunk.
