1991 Beretta 3.1 TCC Solenoid Plug
GMC
ROBORT
  • 8 POSTS
Can someone tell me where the plug is for the tcc solenoid on a 1991 beretta 3.1 is.
Mar 11, 2006 at 2:38 PM
JPAM
  • 307 POSTS
should be on top of trans side cover.. ill look quick to see if i can find diagram/... jess s.
Mar 11, 2006 at 2:40 PM
ROBORT
  • 8 POSTS
I cant see it. Do I have to remove the air ceaner box to get at it?
Mar 11, 2006 at 2:52 PM
JPAM
  • 307 POSTS
couldnt find one right off hand..but [b:b1a1cf9462]mvannessjr[/b:b1a1cf9462] would be the one to listen to.. he should be able to answer for sure, id say by noonish SUN.. Unless he's a church goer then give extra time..
Hey mvannessjr no pressure.. :)
Torque Convertor Clutch Solenoid
good luck jess s.
Mar 11, 2006 at 2:53 PM
JPAM
  • 307 POSTS
well its in that general direction.. id say if you pulled the air cleaner off you might beable to find it..
Mar 11, 2006 at 2:58 PM
JPAM
  • 307 POSTS
cool..thnks for the site, I'll save site for future refrences... thnks jess s.
Mar 11, 2006 at 3:23 PM
MVANNESSJR
  • 223 POSTS
Sorry about that, was a busy day at work yesterday. Glad you found it, and great picture! Yea, TCC seems to be my specialty. *groans*
Mar 13, 2006 at 12:28 AM
ROBORT
  • 8 POSTS
Well I pulled the wire off the tcc bought a new battery and insured the car. Ive been driving it for 1 week but the rear bearing on my alternator blew and it fried so I replaced the alternator on Sunday. Otherwise its working fine.
Mar 20, 2006 at 11:07 AM
JPAM
  • 307 POSTS
good deal... and good luck with the car..
jess s.
Mar 21, 2006 at 3:25 PM
Suggested Repair
Look for the TCC solenoid plug on top of the transmission side cover. Remove the air cleaner box if needed to see and reach the connector.
Conversation Summary
The owner asked where the TCC solenoid plug is on a 1991 Beretta 3.1. An expert said it should be on top of the transmission side cover and that removing the air cleaner may help locate it. The owner later found the connector, disconnected the TCC wire, replaced the battery, and later replaced a failed alternator. The car was otherwise reported to be running fine.
