1996 Chevy Beretta oil light question???
1996 CHEVROLET TRUCK
DALESKI
My wife has a 1996 Beretta w/ 100,000 miles on it. I'm very confuesed. It seems like every time you hit a bump or stop at the bottom of a hill all the lights go wacko.The oil light will stay on for a few seconds and the car will want to stall out, But I just throw it in N and give it some gas, then it's fine. Until I hit another bump. I cleaned my battery cables, tightened them up, changed the oil ond filter, also put in new plugs and wires. Does anyone know what else to do befor I take it in.
Jan 10, 2006 at 7:45 AM
2CARPRO JACK
  • 11,533 POSTS
check the grounds, also see if the batt cables are tight. Might even be the battery itself
Jan 10, 2006 at 9:40 AM
DALESKI
[quote:538d098489="2carprojack"]check the grounds, also see if the batt cables are tight. Might even be the battery itself[/quote:538d098489]
Thanks alot. That's exactly what it was. When we had the transmision replaced 2yrs. ago a company that is supposed to specialize in tranny work didn't put a ground on the transmision. The shop I took it to said they are suprised that it lasted this long. Thanks for your help.
Jan 13, 2006 at 3:35 AM
