1994 Pontiac Sunbird Battery Drain
NT1039
I have a 94 pontiac sunbird 2.0L, 4cylinder that has been having lots of starting issues. i've been at the same shop and they've replaced the starter, then the alternator, and most recently the battery b/c is just doesn't want to concsistently start. each time it works for a week maybe, then some new problem arises. now they're saying i need to replace the abs module b/c that is draining the battery. i got the car back and after a couple of days when i went to start it, it wouldn't but had juice and i heard this ticking that wouldn't stop even w/o the key in. that drained the battery and i'm being told it needs to be replaced. it really seems like there is something else going on. is this all just a coincedence or could there be some underlying problem?
Oct 29, 2007 at 8:19 AM
2CARPRO JACK
  • 11,533 POSTS
A large draw like the ABS motor will kill a battery in no time. Try charging the battery and then pull the ABS fuses. See if it is ok in the AM
Oct 29, 2007 at 9:07 AM
Suggested Repair
Charge the battery, then pull the ABS fuses and check the next morning whether the battery still drains. A large draw from the ABS motor can kill a battery quickly.
Conversation Summary
The owner of a 1994 Pontiac Sunbird 2.0L reports repeated starting problems after the starter, alternator, and battery were replaced. The shop now says the ABS module is draining the battery. After the car was returned, it would not start, ticking continued with the key out, and the battery drained. The expert says a large ABS motor draw can kill a battery quickly and advises charging the battery, pulling the ABS fuses, and checking it the next morning.
