1992 Pontiac Sunbird Stalls at Stop
PHILLYPHRIEND
1992 Pontiac Sunbird SE, 53000 miles. Recently had my car tuned up at the shop with manifold gaskets replaced, new thermostat, fuel filter, air filter, engine spark plugs, radiator hose, ignition wires, coolant temp switch all replaced. The other day drove for about 7 miles on the highway and got off an exit and car started to rattle then stalled out at the light. It started right back up but stalled out when I put it into drive. Waited for 5 minutes started it and drove to the next light and it stalled out again. This did not happen before I got it tuned up. Is this a fuel pump problem or could it be something else? Thanks :cry:
Apr 14, 2006 at 7:44 AM
LOSONE
  • 1,616 POSTS
TAKE IT BACK and make them fix it. There is no telling what they did or what might be wrong. If they refuse make some noise like legal problems. They should help you. Good luck
Apr 14, 2006 at 10:42 AM
PHILLYPHRIEND
Thanks! It was a vacuum leak. Dealer fixed for free. All better...for now :wink:
Apr 17, 2006 at 2:56 PM
Suggested Repair
Return the car to the shop that did the tune-up. In this case a vacuum leak was found and repaired at no charge.
Conversation Summary
The owner of a 1992 Pontiac Sunbird reported stalling when coming to a stop after a recent tune-up and related parts replacement, and asked whether the fuel pump was at fault. The expert advised taking it back to the shop. The owner later reported that the dealer found a vacuum leak and fixed it free of charge.
