Won't start after warmed up
2CARPRO JACK
  • 11,533 POSTS
You will have to check for spark and fuel pressure to see which is missing. If it had a cam sensor code in it, replace the sensor, but I would still see what is missing when it wont start.
Wednesday, November 13th, 2019 AT 6:07 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
The fuel pressure looks good is the security light on solid or flashing with the key in the run position?
KULAN12
I checked for spark and fuel pressure and both are fine. Fuel pressure was about 56 when it was cranking but not turning over and there was spark. There is no check engine light, so I am receiveing no codes. ANy other thoughts?
SMILEYSCHIC
  • 8 POSTS
When I turn the key in the on position the light does not come on at all. Without the key on it flashes.
JEMFRANKS
  • 7 POSTS
  • 2002 PONTIAC MONTANA
  • 140,000 MILES
I have spark and fuel in the fuel rail. Have changed plugs and wires, fuel filter and starter. Weather does not seem to be a factor. Once the engine is running it runs great. My mechanic says he does not know what it is, he said we would have to start changing sensor. Do you have any ideas?
2CARPRO JACK
  • 11,533 POSTS
Now you need to check for injector pulse. You will need to plug a "noid" light into the injector plug to see if it flashes while you crank the engine. Still thinking you may have a bad cam sensor
DJCL
  • 767 POSTS
Are there aney pcm codes. If yes what are thay. We need to know if we are having a spark or fuel. Problem. Check fuel pressure check spark @ the plug on 2 wires. Let me know how you make out.
SATURNTECH9
  • 30,869 POSTS
Have you checked to see if the injector fuse is blown? Do you have power to one of the wires going to injectors with the key in the run position.
KULAN12
One school of thought is the Pass Key security system. The other, the SERVICE ENGINE SOON light just came on and stated CAM SENSOR A code. Not sure if this will fix the occassional non starting, but I will replace it.
JEMFRANKS
  • 7 POSTS
There are no codes, fuel pressure is 50 psi, checked spark on the front three plugs and I have spark on all three.
SMILEYSCHIC
  • 8 POSTS
Fuse is good. Yes there is power to the injectors
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
DJCL
  • 767 POSTS
Is this what you have when its not starting?
SATURNTECH9
  • 30,869 POSTS
Have you ever heard of a injector noid light?You plug it into each fuel injector connector then crank the engine watching for it to flash. It wouldn't be a bad idea to scan the engine and body control module for codes as well.
JEMFRANKS
  • 7 POSTS
When it is not running I still have spark and 50 psi fuel pressure.
SMILEYSCHIC
  • 8 POSTS
We reset the security system. Turned the key to the on position let it sit for 10 minutes, turned it off and the van started right up. We let it run for about 5 minutes shut it off and tried to start it again but it wouldn't start. Did we do the security system right?
FIXITMR
  • 9,990 POSTS
Are injectors working when no start happens?
SATURNTECH9
  • 30,869 POSTS
If it started from one 10 min cycle then it has nothing to do with learning the pass lock sensor. But sounds like you have a problem with the security system. Your going to need to have professional scan tool that can read the body control codes.I would need the exact code numbers not code descriptions? Might even need that scan tool to diagnose the problem by looking at live security data. You could have a bad pass lock sensor. That's most likely the problem.
MR.ELDRIDGE
  • 27 POSTS
  • V6
  • FWD
Have no fuel pressure at rail. Have injector pulse have spark. Fuel pump works 90 psi at filter 0 psi on rail.
JEMFRANKS
  • 7 POSTS
Don't know how do I test.
