2000 Pontiac Montana The engine will not start
BUSYMOM
  • 2000 PONTIAC MONTANA
Engine Mechanical problem
2000 Pontiac Montana 6 cyl Front Wheel Drive Automatic 73000k miles
We just replaced the battery today, as the previous battery was no longer any good. The van gets power but will not start. When you turn the key, we here a clicking but nothing happens, and then it goes dead. We don't know if it is the security feature, which we tried to reset, or the starter or something else. Do you have any ideas on what it might be?
Tuesday, March 24th, 2009 AT 9:55 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Did you try to jump start it? If not try it. If it starts take battery and have it tested. It doesn't happen often but it happens, you may have gotten a bad battery right off the shelf.
Tuesday, March 24th, 2009 AT 10:25 PM
BUSYMOM
We did check the battery and it is good. We had it started briefly and then died. We were told that it is probably the security system and it shut the fuel off. We have tried to reprogram it a few different ways, but it still will not work. When we try to start it, you can hear spinning and then it just dies. Any ideas?
Monday, March 30th, 2009 AT 7:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
It could be a combination of problems.
First it sounds like you possibly have a starter issue.
Next could be a sensor or other problem.
Is you engine light on? If so will need to see about getting codes pulled.
Friday, April 3rd, 2009 AT 1:48 PM
BUSYMOM
Well we tried everything, and the new battery we were given was bad, however, it turns out the PCM theft module was not working and had to be replaced.
Thanks for all of the ideas!
Monday, April 13th, 2009 AT 8:11 PM
