2000 Pontiac Montana why wont my van start?
85,000 MILES • 6 CYL • FWD • AUTOMATIC
HEM315
i changed my fuel filter and now my van wont start unless i turn the key in the on position about 7 or 8 times, then it will start and then stops right after it starts.
Feb 1, 2010 at 11:21 AM
  • 75,988 POSTS
Do you hear the fuel pump come On for a few secs when you turn key to run position-If so check the fuel pressure with a gauge if its within specs. If not check fuel pump fuse and fuel pump relay.
now my van wont start unless i turn the key in the on position about 7 or 8 times, could very well be the ignition switch
Feb 1, 2010 at 11:33 AM
