2003 Pontiac Grand Am overheating
PONTIAC32
  • 2003 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 82,000 MILES
Hi I have a 03 grand am and it just started to over heat while I was driving and leaks coolant out of the over flow in the coolant tank, I changed the water pump and thermostat but still no luck, when I start the car it idels rough for a short time (30 sec) I also have no heat in my car, could this be a head gasket? Or is air getting into my system some how? Thanks
Thursday, September 24th, 2009 AT 12:51 PM
Cooling fans operational and radiator is not clogged-up could be airlock in the system try bleeding it don't work get it block and pressure tested.
Thursday, September 24th, 2009 AT 12:54 PM
PONTIAC32
Ok ill look into it, but also sometimes when I start it, it has light smoke coming out the muffler that smells like coolant
Thursday, September 24th, 2009 AT 4:13 PM
Could be just condensation for a cold engine after the engine is fully warmed-up and still smell like coolant -could be a blown headgasket, cracked head or block
Thursday, September 24th, 2009 AT 4:35 PM
Related Engine Overheat Content
Is Your Engine Cool Enough to Check?
VIDEO
