1994 Pontiac Grand Am car gets hot
VANESSA2205
  • 1994 PONTIAC GRAND AM
Engine Cooling problem
1994 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic n/a miles
car gets hot but cools down quic. No oil in waterand no water in oil replaced thermostat new radiator. New goose neck the fan comes on on the radiator
Sunday, March 29th, 2009 AT 2:30 PM
Recheck the thermostat and bleed the cooling system if it continues do below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following:, Pressure test the Rad. Cap, Clogged radiator, air lock in the cooling system, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Sunday, March 29th, 2009 AT 3:02 PM
