Overheating
14,400 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JERRYWINSTON336
My car started overheating I replaced the radiator water pump thermostat coolant level sensor coolant temperature sensor serpentine belt the car is still overheAting I checked the fans they are operating properly it just keeps overheating I also checked the engine oil to see if it looked normal and it does I looked at that to see if it could be a blown head gasket problem oil looked normal
Apr 4, 2017 at 12:05 PM
HMAC300
  • 48,601 POSTS
pressure check cooling system for an internal leak like a head gasket. then when hot check radiator with engine off and fans unable to start for cold spots if any the rad is bad
Apr 5, 2017 at 12:11 AM
STEVE W.
  • 15,419 POSTS
Looks like you replaced all the external parts. Run a pressure test as well as a combustion gas test. It sounds like you have a failing head gasket that is causing the overheating.
Another possibility would be a partially plugged exhaust holding heat in the engine, for that a simple back pressure test of the exhaust would rule that out.
Apr 9, 2017 at 6:48 AM
