HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine
Symptoms
Overheat
SPONSORED LINKS
1997 Pontiac Grand Am
MKS1302007
MEMBER
1997 PONTIAC GRAND AM
Engine Cooling problem
1997 Pontiac Grand Am 4 cyl Front Wheel Drive 235000 miles
MY CAR IS STEAMING FROM THE RIGHT PASSENGER SIDE. I HAVE A 2.4 ENGINE. IF IT COULD BE THE WATER PUMP, IS THERE A WAY TO TEST IT?
Tuesday, September 22nd, 2009 AT 1:49 PM
MECHANIC
Chances are that is what it is. There is a weep hole on the underside of the pump. If it's leaking, that is where it is coming from.
You can also pressurize the system too. Many parts store will lend or rent the tool.
SPONSORED LINKS
Friday, September 25th, 2009 AT 9:01 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1997 Pontiac Grand Am Over Heating
Engine Cooling Problem 1997 Pontiac Grand Am 4 Cyl Two Wheel Drive Automatic 1ook Miles Overheats Turn On Heater And Does Not Help...
Asked by
jrw1602
1997
PONTIAC GRAND AM
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1997 Pontiac Grand Am Overheating
Engine Cooling Problem 1997 Pontiac Grand Am 4 Cyl Front Wheel Drive Automatic After Driving About 25 Miles And Turning Off The Engine...
Asked by
beegee69
1 ANSWER
1997
PONTIAC GRAND AM
Car Overheating After Driving About 30 Minutes
The Car Was Behaving Like It Needed A New Thermostat, Running Hot And Overheating. I Replaced The Thermostat And Let It Idle For About 45...
Asked by
jmanganiello
4 IMAGES
1994
PONTIAC GRAND AM
1994 Pontiac Grand Am Car Gets Hot
Engine Cooling Problem 1994 Pontiac Grand Am 4 Cyl Two Wheel Drive Automatic N/a Miles Car Gets Hot But Cools Down Quic. No Oil In...
Asked by
vanessa2205
1 ANSWER
1994
PONTIAC GRAND AM
1999 Pontiac Grand Am Car Gets Hot Very Slowly
My 1999 Grand Am Gets Hot. It Takes A Good Amount Of Time. Its Never Went Into The Red. It Had A Waterpump Put In It 2 Years Ago. If You Run...
Asked by
motocross308
1999
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Online car repair manuals
