HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine
Symptoms
Not Running
SPONSORED LINKS
1996 Pontiac Grand Am new motor and it wont start
RUSSELLCO23
MEMBER
1996 PONTIAC GRAND AM
Engine Mechanical problem
1996 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic rebuil miles
i just put in a new motor have changed a couple parts and still wont fire. It turns but no fire.
Thursday, February 11th, 2010 AT 1:53 PM
MMPRINCE4000
MECHANIC
Recheck all electrical connections, if any are contaminated with oil/coolant, clean with electronics cleaner.
If problem persists, start by having ignition module tested.
SPONSORED LINKS
Friday, February 12th, 2010 AT 9:09 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Won't Start?
It Will Turn Over, But Won't Fire. Only Getting A P0141 Code. What Do I Do? I Put My Hand Over The Muffler And It Is Blowing Air.
Asked by
kedevoe
1996
PONTIAC GRAND AM
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Car Will Not Start And Will Not Crank?
Just Found Out The Pcv Valve Is Broken, But Not Sure If They Will Keep It From Starting. The Battery Is Good (new), Has Gas, No Codes...
Asked by
Paige Owens
2004
PONTIAC GRAND AM
Engine Will Crank But Not Start?
We've Check Fuses, Battery, Compression, Replaced Spark Plugs, Fuel Filter, And Fuel Pump. The Car Will Still Not Start. Any...
Asked by
hughhipp
1995
PONTIAC GRAND AM
Won't Start
I Just Had The Fuel Pump Replaced And The Filter As Well. Now It's Cold Out And The Car Won't Start. It Cranks Great, Very Strong...
Asked by
clyn96
1 IMAGE
2003
PONTIAC GRAND AM
Turns Over But Wont Start
2002 Pontiac Grand Am 2.2 Engine Turns Over But It Wont Start. I Checked The Fuel Pressure And It Read Around 40. The Book Said It Needs To...
Asked by
patrickp
1 ANSWER
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
