1996 Pontiac Grand Am CAR ROTATES BUT WONT START
CETE12
  • 1996 PONTIAC GRAND AM
Electrical problem
1996 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
MY CAR IS HAVING A HARD TIME STARTING IT ROTATES WITH NO PROBLEM BUT IT WONT COME ON AND MY RPM IS NOT COMEING ON NOR ARE MY LIGHT GOING OFF WAT COULD BE THE PROBLEM AND WAT CAN I DO TO FIX IT?
Thursday, May 15th, 2008 AT 6:03 PM
The computer might not be getting an ignition reference signal or its not getting gas do below and let me know what you're missing fuel or spark?
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition
Thursday, May 15th, 2008 AT 6:11 PM
