Jack's right, these trannys had a load of different probs. Without the codes, it's a much wilder guess.
Sounds like when you shut it off, the problem is either "resetting" in the computer's mind or a valve/selonoid is releasing on shut down.
SPONSORED LINKS
Tuesday, April 24th, 2007 AT 8:40 PM
