1999 Plymouth Grand Voyager Trans Compatibility
USAFVET
-I have a 1999 Plymouth Grand Voyager, 3.3 engine, 2 wheel drive, 147,000 miles, And an automatic totally locked up transmission.
-I found a 1999 Plymouth voyager, 3.0 engine, 2 wheel drive, automatic.
- will this transmission bolt to my 3.3 engine?
Thank you for your help.
Jun 1, 2007 at 7:22 PM
2CARPRO JACK
  • 11,533 POSTS
Not real sure. the torque converters will definitly be different.Call a salvage yard, they have books with parts interchangability, can tell you if it will work. PCM wiring harness may be different by just a little , never know.
Jun 2, 2007 at 1:07 AM
TRANSMAN1
  • 29 POSTS
No the 3.3 bolt pattern is different than 3.0 will not bolt to your engine.You will need trans from vehicle with your exact engine.
Jan 28, 2010 at 5:00 AM
Suggested Repair
Do not install the 3.0 Voyager transmission on the 3.3 engine. The bolt patterns differ, and the torque converter and PCM wiring may also differ. Use a transmission from a vehicle with the same 3.3 engine, and confirm interchange with a salvage-yard parts guide if needed.
Conversation Summary
The owner of a 1999 Plymouth Grand Voyager with a locked 3.3 automatic asked whether a transmission from a 1999 Plymouth Voyager with a 3.0 engine would bolt up. One reply was uncertain and suggested checking interchange information, noting possible torque-converter and PCM wiring differences. Another reply said the 3.3 and 3.0 bolt patterns differ, so the transmission will not bolt to the 3.3 and a unit from a vehicle with the same engine is required.
