1991 Plymouth Grand Voyager 3.3
1991 CHRYSLER GRAND VOYAGER
SAMO1056
Runs fine80% of the time. Always starts up and accelerates . Except at times it will die when you put in gear take your foot off brake still runs fine until you touch the accellerater again.Then it dies .It will start back up and revs in gear or with foot on brake take foot off it dies.Sometimes 20 times sometimes just one.Then may not do it again for 2 months but always eventually works eventually Please help been towed and started and ran as soon as it gets home .
Thank You in adavance, Ben
Sep 9, 2007 at 2:22 PM
[quote:4437fe91c6="samo1056"]Runs fine80% of the time. Always starts up and accelerates . Except at times it will die when you put in gear take your foot off brake still runs fine until you touch the accellerater again.Then it dies .It will start back up and revs in gear or with foot on brake take foot off it dies.Sometimes 20 times sometimes just one.Then may not do it again for 2 months but always eventually works eventually Please help been towed and started and ran as soon as it gets home .
Thank You in adavance, Ben[/quote:4437fe91c6]
Have the IACV or speed controller-clean out and check the EGR open it up and inspect for carbon on the pintle and passages.
CEL is it coming On?
Sep 9, 2007 at 9:55 PM
