Jack
1993 Plymouth Grand Voyager Camber
Jack
Suggested Repair
Loosening the strut-to-hub bolts will change camber and requires a wheel alignment. To avoid that, remove the axle nut, separate the lower ball joint stud and outer tie rod end from the knuckle, and pry the lower control arm down to free the knuckle.
Conversation Summary
The owner of a 1993 Plymouth Grand Voyager is replacing the left axle and cannot remove the hub assembly. The strut bolts and lower ball joint nut are loosened, and the owner asks whether that changes camber, how to reset it, and whether the ball joint and outer tie rod must come out. The expert says strut bolt movement requires realignment, and recommends removing the ball joint stud, tie rod end, and axle nut, then prying the lower control arm from the knuckle so alignment is not disturbed. The tie rod end still must be removed either way.
