Plymouth Voyager starting problem
BLEWZER
  • PLYMOUTH VOYAGER
My 1988 plymouth voyager that I recently purchased is having problem starting after it warms up. When I turn it off and then return to start it again it starts but then dies after couple seconds. If I wait 5-10 mins it will start and go. I've had the fuel filter and fuel pump changed. Could it be a sensor? It is getting worse each day.
Saturday, April 29th, 2006 AT 4:04 PM
VANDRAGON
  • 298 POSTS
It is very important that you always give info about what motor, trans, miles and work that has been done. With out that info it's just a crap shoot!
Sunday, April 30th, 2006 AT 9:00 AM
DDUBOIS55
  • 5 POSTS
I have an 88 voyager which has been great except for the starting problem you mentioned with yours. This has happened 4 times with my van and each time it was related to the fuel pump. Its been replaced each time for about $300. The last time it happened, I had just replaced the pump. I discovered that there is a plug in the wiring to the pump that gets corroded. I unplugged it and plugged it back and the van started.
Friday, June 9th, 2006 AT 5:35 PM
