If you hear the pump chances are it is working. The next question is "Are you getting fuel to the rail?".
Try checking the fuel pressure or carefully just test for fuel; at the valve at the rail.
Check the spark plugs. Are they firing? Are the black, wet, white, dry?
Post back with your results. Good luck. :)
SPONSORED LINKS
Friday, March 24th, 2006 AT 4:56 PM
