1989 Plymouth Voyager starting
CARSANDTRKS5
  • 1989 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 168,000 MILES
If it is driven on a day above 80%or humid it will not restart or may not even start at all. Replaced fuel pump fuel relay. It turns over fine and has spark off coil.
Tuesday, May 4th, 2010 AT 10:25 AM
CARADIODOC
  • 33,916 POSTS
Hi carsandtrks5. Welcome to the forum. Since you have spark, that leaves out a lot of stuff including whatever sensors are used depending on which engine you have. When it doesn't start, check for fuel pressure. The 3.3L has a test port on the fuel rail. It looks exactly like a tire valve. Pressing the valve should cause fuel to spray up to the hood for a fraction of a second. If it does not, suspect a stalled fuel pump. Banging on the bottom of the fuel tank while a helper cranks the engine will often get it started. Once it's running, it will rarely quit while driving. They almost always fail to start up. Be aware though the pump should only run for one second after turning on the ignition switch, then it will turn off. It must start running again during engine rotation, (cranking or running).
Another fast way to check for worn brushes in the fuel pump motor is to pop the cover off the fuel pump relay, reinstall the relay, then watch very closely for a tiny spark at the contacts when you squeeze them. Lack of a spark means there is no current flowing to the pump, possibly due to a burned electrical connector terminal at the pump, but more likely due to worn brushes in the motor.
Caradiodoc
Tuesday, May 4th, 2010 AT 2:29 PM
CARSANDTRKS5
Yesterday it got [hot] out van would not start all day then this morning started fine. [Cool] this has been going on for a yr. It's only used for flee market on sunday's has had 3 pumps in 2 yrs, and when it gets hot after it wont start. Runs great starts all day if 60 degrees out. Only does it over 75-80 degrees or humid out.
Tuesday, May 4th, 2010 AT 2:55 PM
CARADIODOC
  • 33,916 POSTS
Which engine do you have?
Caradiodoc
Tuesday, May 4th, 2010 AT 3:00 PM
CARSANDTRKS5
3.0 has also had shut relay replaced and has spark
Tuesday, May 4th, 2010 AT 3:02 PM
CARADIODOC
  • 33,916 POSTS
Yup. If it has spark, the Automatic Shutdown (ASD) relay is working properly. That's why it just leaves the fuel pump or injector circuit.
I had a similar problem with my '88 Grand Caravan 3.0L right after I washed the engine. Turned out to be corroded pins in the electrical connector between the throttle body and brake master cylinder. It only feeds the injectors, not the ignition coil. All I did was unplug it and plug it back in. The scratching action on the terminals was all it took to clean them up. I haven't touched it since, and it is still my rusty trusty daily driver.
Use a cheap digital voltmeter to measure the voltage on one of the injectors. There should be 12 volts there for one second after turning on the ignition switch, and always during engine cranking. If it is missing, there is very little that can be the problem. The feed wire goes back to the ASD relay which we know is working.
Caradiodoc
Tuesday, May 4th, 2010 AT 3:12 PM
