Code P0336, Now all I get is puffing sound when cranking but start?
  • 52,797 POSTS
The return or ground is the ECM. If you had the black lead in the connector and read the voltage you posted, then it is good.
Saturday, April 10th, 2021 AT 3:42 PM
AKILLEON SAMPSON
  • 33 POSTS
Apologies Roy my multimeter wasn't reading properly. I'm getting-0.06.
Sunday, April 11th, 2021 AT 2:29 PM
  • 52,797 POSTS
What wire?
Sunday, April 11th, 2021 AT 3:27 PM
AKILLEON SAMPSON
  • 33 POSTS
The signal wire.
Sunday, April 11th, 2021 AT 3:32 PM
AKILLEON SAMPSON
  • 33 POSTS
Red lead on C.
Sunday, April 11th, 2021 AT 3:33 PM
AKILLEON SAMPSON
  • 33 POSTS
Sorry that was on both.
Sunday, April 11th, 2021 AT 3:34 PM
AKILLEON SAMPSON
  • 33 POSTS
(Battery) Positive red to pin 22 7v.
Sunday, April 11th, 2021 AT 3:38 PM
  • 52,797 POSTS
Okay, I am confused.
Can you retest the voltage as I suggested?
Do you have 12 volts to the connector on terminal C or the light green wire?
Also, put your voltmeter leads in the connector. Red lead to C and black lead to B or the yellow-black. Tell me the voltage. It should be battery voltage with the key on.
Sunday, April 11th, 2021 AT 3:48 PM
AKILLEON SAMPSON
  • 33 POSTS
The-0.06 is being displayed with red connected to C and black connected to B. If I remove red and touch positive terminal I get 7v@ B yet C remains the same when touching -terminal.
Is this being done without ecm being connected.
Sunday, April 11th, 2021 AT 3:52 PM
  • 52,797 POSTS
Why? You must have the ECM connected. That is where the power comes from.
Sunday, April 11th, 2021 AT 3:55 PM
AKILLEON SAMPSON
  • 33 POSTS
Just trying to be 100% clear so that I will be able to follow all steps.
Sunday, April 11th, 2021 AT 3:56 PM
  • 52,797 POSTS
The ECM must be hooked with the key on for these tests.
Please retest?
Sunday, April 11th, 2021 AT 4:04 PM
AKILLEON SAMPSON
  • 33 POSTS
It was tested with ECM connected and key on.
Sunday, April 11th, 2021 AT 4:06 PM
  • 52,797 POSTS
The readings you previously posted were with it disconnected according to you.
Please clarify.
Sunday, April 11th, 2021 AT 4:18 PM
AKILLEON SAMPSON
  • 33 POSTS
I did not state that I was clarifying that you weren't requesting it to be unplugged to gain access to the connector hence "is this to be done without ECM connected".
Sunday, April 11th, 2021 AT 4:21 PM
  • 52,797 POSTS
As I stated earlier, the ECM must be hooked up and the key in the on position.
Sunday, April 11th, 2021 AT 4:27 PM
AKILLEON SAMPSON
  • 33 POSTS
I also stated that I performed the test that way. So we have 0.06 @ C. What's next?
Sunday, April 11th, 2021 AT 4:33 PM
  • 52,797 POSTS
What is the voltage on A and C with the ECM hooked up and the key on?
C is the return to the ECM.
Sunday, April 11th, 2021 AT 4:42 PM
AKILLEON SAMPSON
  • 33 POSTS
With red in C and black in A 14v.
Sunday, April 11th, 2021 AT 5:08 PM
  • 52,797 POSTS
Black lead to C and red lead to B and read the voltage.
Sunday, April 11th, 2021 AT 5:26 PM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
