2002 Oldsmobile Silhouette Thermostat Location Fix
2002 OLDSMOBILE
SCHAEFECREW
I need to replace the thermostat in my 2002 Oldsmobile Silhouette (AWD, 89,000 miles) but I cannot seem to locate it. I've changed many thermostats before, but I cannot locate anything that looks remotely familiar. I managed to find the thermostat housing, which is a long pipe with the radiator hose connected to it. Do I need to remove the pipe completely to get to the thermostat? The owner's manual is worthless and there is no diagram of the engine anywhere, any help you can provide will greatly be appreciated.
Feb 15, 2007 at 1:16 PM
CHEVY22
  • 1,375 POSTS
the thermostat is located on the left side of the engine under a crossover pipe if you look closely you can see the housing there are two or three 13 mm bolts holding it in , it loks like a bear to do but it really isnt if you have the right tools, good luck and if you need more help let me knwo
jim
Feb 17, 2007 at 9:31 AM
Suggested Repair
Locate the thermostat on the left side of the engine under the crossover pipe. The housing is held by two or three 13 mm bolts; remove those bolts to access the thermostat. The job looks difficult but is manageable with the right tools.
Conversation Summary
The owner of a 2002 Oldsmobile Silhouette could not find the thermostat and asked whether the long housing pipe connected to the radiator hose must be removed. An expert said the thermostat is on the left side of the engine under a crossover pipe, secured by two or three 13 mm bolts, and that the job is not as hard as it looks with the right tools.
