1996 Oldsmobile Silhouette Head Gasket Fix
GMC
ADICKEY
Hey guys! I need some advice. I have sent my 1996 oldsmobile silhouette v-6, EFI, to be have the head gasket replaced. I talked to the guy this evening and he tells me that he has figured out that he cannot do it, because he does not have a lift, in order to get under the van and take out the motor. He is able to get one head off but not the other, without taking the motor out, and he says that he can't get the motor out unless he goes from the bottom. Since he doesn't have a lift, he can't do it. Is there anyway he can go from the top? He says that if he does try and remove it from the top, it will do some serious damage to other things.
Thank you,
Thouroughly annoyed.
May 12, 2006 at 2:06 PM
LOSONE
  • 1,616 POSTS
You should be annoyed. I have done the job from inside the vehicle. You simply have to remove a lot of things to get to the head. It sounds like he doesn't want to do the job or underestimated it. Good luck
May 13, 2006 at 7:06 AM
Suggested Repair
The head gasket job can be done from inside the vehicle without a lift by removing the many parts that block access to the heads. Engine removal from below is not required if enough clearance is created.
Conversation Summary
The owner sent a 1996 Oldsmobile Silhouette for head gasket replacement. The shop said it could not finish because it has no lift and believes the engine must come out from below to reach one head. An expert said the job can be done from inside by removing many parts for access and that the shop may have underestimated the work.
