2000 Oldsmobile Silhouette Runs Hot
mmm!! , but Fans don't come on till 200*
A cooling system needs a way to turn the radiator fan on og off as it's needed.
This function is usually performed by a coolant temperature switch. A coolant temperature switch is temperature controlled , so the switch is mounted somewhere in the cooling system where it's directely exposed to the coolant
The switch could be mounted anywhere in the system, check it out in your Haynes manual . that could help you.
Not trying to pick a fight, just learn somthin :)
I know these are common for intake leaks, but short of a high but ok temp reading it doesn't seem evident.
Waiting on Blackstone oil diag kit to send in a sample for analysis for possible water.
What is the feeling on keep using dexcool after 100K
miles or should I have switched to what?
I have had a heck of a time to decide the "right" way to handle the coolant issue. 8) I spent considerable time to try to understand the how and whys. Conflicting results :?
Between the engineering, marketing and illusions the answer is difficult.
I would either stay with dex-cool or a long life coolant if it were mine, as it came with it. If you add anything else, it will become the lower common denomenator. If so, stay with that.
Looking forward to what becomes of your situation :)
Suggested Repair
Closely inspect the intake manifold for small coolant leaks that can dry from engine heat before becoming visible; these vans are known for intake leaks. Fan activation near 210 F is about normal because the PCM controls the fans from the coolant temperature sensor. Continue using Dex-Cool or an equivalent long-life coolant and do not mix coolant types.
Conversation Summary
The owner of a 2000 Oldsmobile Silhouette with about 101,000 miles reports the temperature gauge rising past 3/4 at idle, then dropping after the fans come on around 200 F. Sensor, relay, flush, and leak checks showed no coolant loss or oil contamination, and the fans also run with the A/C. Experts say fan-on near 210 F is about right and recommend a close intake inspection for small leaks. They also advise staying with Dex-Cool or long-life coolant.
