98 Sable Radiator Fan not shutting off
1998 ALL OTHER MAKES ALL OTHER MODELS
BENPIMLOTT
Hi, I have a 98 Sable, 95k Miles and the cooling Fan does not shut off while the engine is running. When ever you start the engine the cooling fan kicks in after a few secounds and dosent stop untill you turn off the engine. this happens whether the engine is cold or hot.
I went to a parts store and explained the issue and they thought it might be a temp sensor. I bought it and replaced it. But still does the same thing, are there are other sensors that control the Fan?
Your help is appreciated!
Thanks
Oct 18, 2006 at 7:27 AM
VIENERSLIDER
  • 5 POSTS
My question is the one a few down from yours...."Fan" sounds like the same problem......Same car same year......sounds like it's doing the same thing as your's. if I find out I'll let you know......and if you find out....Maybe you can share the info with me.......thankx
Oct 18, 2006 at 3:59 PM
