I have a 1997 Olds Silhouette Van with 161821 miles. How do I get the battery out. Thank You
May 4, 2006 at 6:20 AM
Remove the battery cables with an 8mm wrench, ground first. Take off the plastic cover and the black brace over the battery, then remove the 13mm bolt on the back of the battery to free the plastic hold-down block.
The owner of a 1997 Oldsmobile Silhouette asked how to remove the battery. The expert said to disconnect the cables with an 8mm wrench, ground first, remove the plastic cover and black brace, and loosen the 13mm bolt that releases the plastic hold-down block.
