1991 Oldsmobile Cutlass Testing the ignition coil
1991 OLDSMOBILE CUTLASS
200,000 MILES • 4 CYL • FWD • AUTOMATIC
SABRES_GUY
I have a 91 Oldsmobile Cutlass Calais 2.5 litre and the engine has dropped down to using 2 cylinders Front I am getting no spark in from the spark plugs need to check the Ignition coils but don't know how. please help, any other suggestions would be helpfull too.
Jan 15, 2008 at 6:27 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
all you have to do is disconnect the plug wire to #1 cyl and see if there is spark. 1 and 4 share the same coil. 2 and 3 share the same coil. **i always replace the coil that is not firing and i also install a new ignition module. it always seems that if you dont replace them together it will burn you by doing the same thing a week later.
Jan 15, 2008 at 6:37 PM
