1991 Oldsmobile Cutlass NO POWER TO COIL PACK
1991 OLDSMOBILE CUTLASS
147,054 MILES • 6 CYL • FWD • AUTOMATIC
SCOTTYSCOTT72
I have a 91 oldsmoble that wont start, it is getting gas, and the starter is good however there is no fire going t0o the engine. it was running just fine mabye a little on the rough side but I turned it off for a second and when i went to start it, my thumb slipped off of the key and it diod not complete the start and when i attempted to start it again it would not start. I pulled a plug to see if there was fire and nothing...i have had this happen before and i would disconnect the battery and wait a few minuets and it would start, it has a coil pack, i had the crankcase sensor replaced a few week ago...could someone help
Jun 18, 2010 at 8:32 AM
SATURNTECH9
  • 30,869 POSTS
There is a lot of cutlass model's which one do you have?All so what size engine do you have?
Jun 18, 2010 at 11:44 AM
SCOTTYSCOTT72
it is a 1991 cutlass creia with a 3.1 v6
Jun 18, 2010 at 11:48 AM
SATURNTECH9
  • 30,869 POSTS
It's just a plain ciera?They have a S or SL model as well.All so have you checked the car for code's?They only list a 3.3 for all the ciera model's are you sure it's not a 3.3?Let me know.
Jun 18, 2010 at 12:21 PM
