Turn signal not working
FIXITMR
  • 9,990 POSTS
Try lubing hazzard switch. It interacts with turn signals. Or just replace it? You also may have a bad multi sitch which is your turn signal assembly. Could be wire loose or bent contact, etc.
Friday, June 26th, 2020 AT 12:48 PM (Merged)
SIMON10
If you haven't already got the issue fixed, try calling a gm service tech and provide them with your vin number. I have a 2000 that did the same thing and it was recalled so they fixed it for free. It has something to do with bad soldering.
LOGANB13
  • 2004 OLDSMOBILE ALERO
  • 90,000 MILES
When you start the car the blinker works but when you put the car in drive and start driving it stops working.
Friday, July 17th, 2020 AT 4:23 PM (Merged)
STEVE W.
  • 13,560 POSTS
All blinkers or just one? Do they work in reverse? Neutral? Do the hazard flashers work in drive?
ASHWOME
  • 2001 OLDSMOBILE ALERO
  • 4 CYL
  • 142,217 MILES
My blinker works when it wants too, should I pay $200-$400 to get the wiring fixed or is this a simple fix that I can do?
Friday, July 17th, 2020 AT 4:33 PM (Merged)
KNOWYOURAUTO
  • 113 POSTS
Ashwome,
Has an inspection been performed that found a wiring problem? If that is a shops diagnosis, ok; however, the common failure for this problem is the turn signal/hazard flasher mounted in the center of your dashboard.
Next time your turn signals don't activate try rapping firmly near the hazard button, preferably above it without actually touching the switch. The relay contacts often fail and may reconnect from the bumping. If this is symptom, I recommend taking it to a dealer that has performed this repair before. Removing the center vent and two 7mm screws is difficult without damaging either component.
Regards,
KnowYourAuto
SUGAREE53
  • 7 POSTS
  • 2000 OLDSMOBILE ALERO
  • 85,000 MILES
Sometimes it works sometimes it doesnt
Friday, July 17th, 2020 AT 4:35 PM (Merged)
  • 109,867 POSTS
When it doesn't work, do any of the lights come on?
SUGAREE53
  • 7 POSTS
No inside turn signal lights come on or outside either
  • 109,867 POSTS
It sounds like the switch itself is bad. I would check that first.
SUGAREE53
  • 7 POSTS
Sometimes I hear a buzzing sound when I turn on signal light and it doesnt work
  • 109,867 POSTS
Is the buzzing coming from the switch or under the dash?
SUGAREE53
  • 7 POSTS
The dash I think
  • 109,867 POSTS
Try replacing the flasher. It could be the problem.
SUGAREE53
  • 7 POSTS
Thanks jacoband nickolas for your quick response
  • 109,867 POSTS
Let me know what you find. The flasher is a cheap part.
